tac0meat
- May 29, 2000
- 91 EB 2x4
im planning on ordering a 200 amp altenator from Mr. Altenator. for some reason its sticks in my mind that many of you have ordered high output altenators from Mr. Altenator, and was wandering if it is relatively easy to install. does it come with all the parts i need to do a simple swap, are there a bunch of electrical connections to modify or are there just a couple of wires to plug in? ive changed the serpentine belt so im assuming this will be about the same amount of effort right? just take off the belt undo a couple of wires and bolts and swap the new one in, hook it back up and im ready to go? if you guys say it will be similar to what i said earier(relatively easy) then im going to order it tonight. thanx in advance.
