Robs 2010 Fords
- January 18, 2025
- San Rafael, CA
- 2010 Explorer XLT 4X4
Hi folks,
My 16 year-old son and I bought this vehicle 10 months ago. 150k miles. Recently, the wrench and CEL lit up and the transmission went into limp mode No overdrive-off response. It clunks a little when shifting into R and D. Smooth from D to 3. There is a leak from the front of the transmission, and the shift lever cycle seems loose.
Codes were:
P0316- Misfire detected
P0713- Transmission fluid temp
P0731-Gear ratio incorrect
P0732-Gear ratio incorrect in 2nd
P0733-Gear ratio incorrect in 3rd
P040 -Torque converter fault
P0743-TCC System fault
We dropped the pan, and the fluid level was low and varnished. There was some metal on the magnet, but not much. We changed the filter, added fluid.
Codes now are:
P0743 - Torque Converter Clutch Circuit Electrical
P0750 Shift Solenoid A Malfunction
P0755 Shift Solenoid B Malfunction
P0760 Shift Solenoid C Malfunction
P0962 - Pressure Control Solenoid A Control Circuit Low
P0966 - Pressure Control Solenoid B Control Circuit range/performance
P0966 - Pressure Control Solenoid B Control Circuit Low
P0970 - Pressure Control Solenoid C Control Circuit Low
Are any other things an intermediate mechanic should try or is it time to punt? I can replace
Codes were:
Codes now are:
