2013 Will Crank but not start, only when hot | Ford Explorer Forums
WineAviator
New Albany, IN
2013 Explorer Limited
2013 Ford Explorer, 133k miles, normal service, spark plugs, battery, etc. Starts just fine cold but once hot it will not start. Cranks just fine, but does not fire. Open the hood and let it cool off for 10-40 minutes and it fires right back up again. Coolant Sensor? Crank Sensor?
Any help would be greatly appreciated as I believe the coolant sensor involves removing the intake manifold.
No error codes, no CEL, just cranks and doesn't start. Soon as it cools off, bingo, fires right up.
Thanks in advance everyone.
Welcome to the Forum. :wave:
I can't recall if this issue has been posted before. There are several threads on "crank but won't start" issues but none that I found were identical to your problem. Have you tried starting with the accelerator right down to the floor?
