2015 - Crank but no Start | Ford Explorer Forums
normanburt1970
Conroe, Texas
2015 Explorer Limited
Hey y'all,
The water pump went out on my 2015, 3.5L NA (102k), so I tore it down and replaced it. But, since putting it back together I'm getting ,crank but no start. I've checked for spark and that's fine, I've checked for fuel and that's fine. There are no codes present.
Any of you ever experienced this?
Thanks
Hi Norman,
1. Can you better describe the cranking? Is it normal sounding or slow/sluggish?
2. When you say no errors, do you mean there’s no warning displayed in the message center, or that when you scan all systems using a DTC scanner (ideally, Ford specific), all systems are OK?
Regards,
Riggy
Welcome to the Forum Riggy. :wave:
Hey y'all,
Thanks
Are you sure that the timing is correct?
