Well, I think that should eliminate the starter. Perhaps it isn't always getting fuel or firing when it does. How many miles are on it?Hey thanks for replying, it actually makes the trying to start noise like the engine goes but just doesn't complet the start.
Welcome to the Forum.Having a similar issue with my wife's 2019, crank no start and no fuel pressure. i get 10.8 volts at the pump. does it need to be 11 or above to operate or is the pump in need of being replaced? The first two times it happened just disconnecting the battery for a couple hours and it would start. My thought at first was bcm. I dont believe they have inertia switches any longer , they call them a fuel pump driver?
I will have to take a look, thanksWelcome to the Forum.
Your Explorer does have a Fuel Shutoff feature. It is explained on page 259 of the Owner's Manual (2nd print) under Roadside Emergencies.
Is that function controlled by the fuel pump driver module or pcm or bcm? Just curious.I will have to take a look, thanks
That, I don't know. Perhaps another member will jump in.Is that function controlled by the fuel pump driver module or pcm or bcm? Just curious.
Well we were able to see that when starting there is no fuel coming up the fuel line so I guess that jump was a coincidence. Weird part is on the occasion when it does start there is no issue at all with fuel once it is on. Once its on, its good and drives totally normal, no hesitation, no rough idle, normal.So weird, I was able to jump the vehicle today and it started but had to be coincidence because tried it again and nope. also tested battery and fine.
Perhaps it is that your fuel pump is starting to fail. I don't know what else would prevent the fuel from being pumped. Anyone else have any ideas?Well we were able to see that when starting there is no fuel coming up the fuel line so I guess that jump was a coincidence. Weird part is on the occasion when it does start there is no issue at all with fuel once it is on. Once its on, its good and drives totally normal, no hesitation, no rough idle, normal.
I took it to a local mechanic to see what he thinks...I'll update once they take a peek at it. I would think if it was the fuel pump it could still have that issue while driving it, I dove it for 14 hours without turning it off and no issues. This was after it left me stranded and then magically decided to start up again after the dealer said they can't find an issue.Perhaps it is that your fuel pump is starting to fail. I don't know what else would prevent the fuel from being pumped. Anyone else have any ideas?
Might be time for a dealer visit.
My issue wound up being my fuel pump went bad...at 68K..crazy.Hello
Same problem here. Yesterday afternoon, reading this forum saved me a hassle, as I was in the 1/4+ fuel level, maybe not parked level (I mean maybe) camp and it wouldn‘t start. Tried that procedure in the manual for re-starting and that didn’t do anything. Pushed it across the parking lot, topped off the tank, and away we went. It’s started and run well on several trips in the past 24 hours hours.
This evening, it won’t start again. Cranks and it wants to start, it flutters a bit, just needs fuel (I think). This is at least the 3rd instance, maybe 4th, and each one is progressively more challenging to get it started.
Trying to trouble shoot, here are my observations:
It’s been hot here, unusually so for us northerners, and the trouble has been after trips of 30 - 90 minutes in the heat of afternoon, AC running and it’s hot under the hood when checking.
Today, I tried disconnecting the battery for 30 seconds (lost the clock, but not the radio presets). I tried using the special fuel filling funnel to open the gas fill point in case there was any pressure or vacuum. I let it sit for about 90 minutes, no start, 4 hours now start. Soon, the battery will be down and I’ll have to recharge/jump.
Soon, I’ll have to tow it. With some luck, maybe it will start in the morning and I can drive it to a dealer. Based on others experience, I don’t want to be left with no ideas. I’ll need to start replacing parts and hope to guess well early in the process.
Thanks for any ideas (wife has to work tomorrow and would like me to fix her car) and I’ll try to update if I find a solution. I think it’s clear that there is a problem with these models and it needs a fix. I am operating well within design specs, I’m sure.
Jr
Welcome to the Forum Jr.Hello
Jr
I saw this on a YouTube channel I watch. Turned out to be something internmiddent with the fuelpump. Maybe have them start off by testing the fuel pressure.Got towed to the dealer and it started when they were taking off the tow truck. Dealer has no clue. No codes. Has fuel. Don't have a way to check for spark. Has anyone solves this problem yet!
I agree, shouldn’t be a minimum. It’s about 3/4 full and parked in the driveway where it has started 1000 times.Welcome to the Forum Jr.
How much fuel was in the tank the second time? I don't believe a normally operating vehicle should be 'required' to keep a minimum amount of fuel in the tank under normal circumstances but I try to never let mine go below the 1/4 tank mark. Perhaps it is an issue with the pump.
Thanks for confirmation. I’m around 37k.My issue wound up being my fuel pump went bad...at 68K..crazy.
