2015 explorer block heater install | Ford Explorer Forums
mark strong
humble
2015 explorer xlt
so i recently m9ved to canada and damn its cold here. ive bought the block hester i will need for this winter. it screws inr9 a coolant passage somewhere. it looks like its 19mm. anyone know where the plug im supposed to pull is located. i have thebnom ecobooat v6.
thanks
Welcome to the Forum Mark.:wave:
Did someone move the keys around on your keyboard?;)
I don't know where you moved to but here in eastern Ontario it has been very mild and about 10 days ago it was in the 70's. Getting my Winter tires put on tomorrow and was thinking about postponing my appointment for a while.:)
I don't know if the location for the block heated is different in an Ecoboost but using the Forum's handy 'Search' feature (upper right) found this thread; http://www.explorerforum.com/forums...r-install-for-2013-explorer-6cyl-3-5l.435845/
Not sure if will help. BTW, I can't recall the last time I used a block heater. My 2011 came with one but never used it. Good luck.
