DeluxeStang
- July 3, 2023
- SLC, Utah
- 2017 base
We have a 2017 explorer base with a little over 32k on it. It's been great for the most part, but the transmission is starting to do this almost lurch and jolt when shifting at low speeds, usually going from 1st to 2nd in things like parking lots. Does anyone know what could be causing that?
The fluid hasn't been changed yet, but we had dealer techs look at it and they said the fluid is still a healthy red color, and doesn't seem like it needs to be changed out at this time. Some people have told me you can go decades without changing the transmission fluid with no issues if you don't put a ton of miles on the car as is the case for us, it's mostly stop and go drives of a few miles at a time.
So I don't think it's the fluid. What the tech did mention is while these transmissions are quite reliable, it's not uncommon to have to go in and do a bit of a software update on them as they age, and that apparently usually fixes the issue. I don't know what the cost on that would be.
People who've been in my situation, tell me what you would do, or if you've experienced this, what you did that fixed it. Thanks.
