anchored
- February 18, 2003
- W.Va.
- '93 XLT
250,000 Mile Makeover
Ok, so as soon as the weather clears, I'm going to pull under the shade tree and try to revitalize it. Here's my list so far:
1. Repair 4WD using transfer case motor rebuild
2. Repair ABS by cleaning speed sensor hopefully
3. Change Transmission Fluid and Filter
4. New Spark Plugs and Wires
5. New Serpentine Belt
6. Change oil and filter/lube zerks
7. Clean Mass Airflow Sensor
8. Tighten Lower Intake
9. Replace rear bumper and repair rust spots
10. Fix trailer wiring once and for all
11. Find leak around windshield/sunroof and fix it
12. New brake pads
13. Think about new suspension bushings up front
14. Figure out while fuel gage doesn't work (sunken float?)
So what am I missing? Any other sensors, detectors, worn-out things, etc. I should work over?
12. New brake pads
