285/75r16 rubbing issues! | Ford Explorer Forums
DRAGONESKU
Cali
2002 SPORT TRAC 4x4
What's up fellow explorer aficionados I hope you all are having a great year.
About a year ago I bought my current vehicle, an 02' explorer ST 4WD, which is currently running on stock wheels and 265/75r16 All Terrain tires. Thanks to the information available in this forum I was able to do a 1.75'' TT/Shackle lift without a hitch!
The lift and tires looked cool but I need it beefier tires to feel good about myself, so a week ago I bought a set of 285/75r16 Dick Cepek Mud Country tires (they came mounted and balanced), and wheels with these specs;
wheels:
Offset: 0mm
Backspacing: 4.53"
Long story short I bolted those 285/75r16's on and and as I was pulling out of the driveway, and turning, I heard this horrible rubbing screech. Well turned out both front tires were rubbing against the sway bars . I took them off and looked for a solution to the problem. So I bought 1.5'' lug-centric wheel spacers hoping they will solve the problem.
My question is, will the 1.5'' spacers solve the problem, and if not, what might another solution.
Thank you
Rafa
Hi Rafa,
Did you ever find a solution to your problem? I am debating on whether to get these same size tires with a TT/shackle lift and am interested to hear how yours turned out.
