2nd Gen Dash removed...while it's out.... | Ford Explorer Forums
Spdrcer34
Bremerton, WA
1992 Explorer XL
Okay...I am going to remove the dash out of my `97 X, and swap it into my `92....
I am also swapping over to EATC, and adding the Console Computer while it's out, and since I am also pulling the HVAC box, I am replacing the Blend Door...
Couple of OTHER questions for you guys...
Is the Dorman Blend Door built any better than the OEM door? Or does it suffer the same weak spot breakages?
Is there anything else I should attend to while the HVAC box, and dash are out?
Ryan
ooh....Good call!...
My heater core went out on the `92, and it was $20 for the part, and 10 minutes to fix....I guess the 2nd Gen set-up isn't as easy..
Blend Door Fix...check
Heater Core....check
Anything else?
Ryan
maybe take some pics of the process. I have been wanting to take the dash out of mine for a while now to change colors but no clue how to go about doing it
Oh, BELIEVE ME when I say it will be WELL DOCUMENTED!...
Ryan
