willzilla
- July 14, 2010
- San Antonio, TX
- 2000 XLT AWD
Wondering if anyone knows the max wattage LED we can place in the license plate light bulb connector safely? I put in some 6 LED 904 wedge lights rated at 10-16V, 0.35W, & put out 42 lumen and they popped the 15A fuse within about 5 seconds... I swapped in some lower watt cheap 194 168 W5W 2825 Frosted Lenses 12-14 Volts DC 0.18W single LED and the fuse was fine but the light output is much worse :-/
The 6 LED light in question is: http://www.ledwholesalers.com/store/index.php?act=viewProd&productId=337
I'm assuming the higher power draw on the superior 6-LED set is enough to pop the fuse... What is the safe limit on this circuit? I didn't see the electrical wiring diagram max current draw or anything on the schematics just 12V DC power.
Is it safe to perhaps pop in a 20A or higher fuse without risk of melting out something to run these LEDs?
Thanks!
Thanks!
