arred79
- May 16, 2016
- Long Island, NY
- 2019 Explorer Sport
So I was able to obtain a 2nd row refrigerated console from a Ford Flex, and I plan to install it in my '13 Sport, it bolts up identically to our non-refrigerated console, I just need to wire it up. I am pretty handy and comfortable doing things like this, have done wiring projects in the past but wanted to reach out on here to anyone who has done this already or just has good electrical experience. Now the plug that comes out of the console looks like a basic 2 wire power and ground set up, and I want to connect it to an ignition on/run only source. Anyone know where would be a good source to tap for power for this? My Sport does not have a heated steering wheel but I was thinking of using a fuse tap and use the spot in the fuse box for the heated wheel to source power, which I believe uses a 10 amp fuse, and route the wire to the back --- thoughts on that or any other ideas? Just want to make for a clean install and safe wiring.
Thanks,
-Dale
Thanks,
-Dale
