2WD low range | Ford Explorer Forums
2WD low range
scratched 95
Millersburg, Or
95 XLT
I haven't seen this discussed anywhere. The 95 has a vacuum disconnect for the front diff (the only year, I think). If I were to block the vacuum line and put the switch for the transfer case in LOW, would I have 2WD low? Or, does the computer need to see that the front has been switched before it will allow low? Unfortunately, I don't have anywhere nearby to really try it out.
I don't think the computer needs to know as I haven't seen a sensor that detects the front end engagement.
Also the 96 model year has the vacuum disconnect.
Go for it, it shouldn't hurt it.
without sounding dumb, why would you want that?
For extra maneuvarability offroad or for towing heavy loads at a slow speed on the street.
Rick uses 2lo a lot more than 4hi or 4lo on the trail. 2lo is great if you have it :)
