MusicAllTheWay
- July 21, 2006
- Princeton, NJ
- '06 Limited 4x4
4 questions...NEED HELP
I've got a few questions about things I've recently noticed about my '06 Limited V8 4x4 and wanted to see if anyone had any explanation or have experienced them.
1. After I get into the boiling hot car, start it up, and crank up the a/c, even though all the little fan speed lights are up, sometimes the fan is completely dead. Then after 5 or so seconds, it finally clicks on and goes to the high setting. Is this normal sometimes?
2. On slow acceleration in 1st gear before switching to 2nd, the engine sounds like a big UPS truck accelerating in 1st. Know what I'm talking about? Does it have something to do with the new 6-spd trans. and is normal?
3. I'm guessing this one is not normal: At right around 2000rpm, there's a noticeable vibration in both the steering wheel and the gas pedal. It's most noticeable in the lower gears and goes away in the higher. What's happening?
4. Any suggestions for plugging an Ipod directly into the factor nav/radio head unit? Someone I talked to suggested that if the HU was satellite radio ready that I might be able to use that aux with a certain cable to plug into the Ipod instead. Didn't know if he is way off or what. What exactly is the connection between satellite radio and the head unit? Is the receiver built in? Might a connection with the Ipod be possible? I saw with the new '07 Ford Edge SUV that uses the exact same nav/radio head unit, they're making a place to plug in your Ipod.
Sorry for all the questions. I feel like I bought a car that I don't know anything about.
Thanks for your help though!
