scramblin
- December 11, 2001
- russellville, AR
- 96' Ford Explorer XLT
I'm currently working on a 302 5.0 HO swap in my 96' explorer. I will be pulling the old motor out in ~a week. I have quite a few questions though!
Fuel Pump: I have done some reading and decided that my stock fuel pump will be fine. Am I right?
Wiring Harness: I have both a 5.0 and a 4.0 harness. Does anyone know of a write-up about merging these two harnesses together? If not, Where can I find that info?
Computer: Anyone know if the 5.0 computer will fit into the firewall hole where my 4.0 computer is at?
Motor Mounts: Will the stock mounts from a mustang work? Or would it be best to buy some new ones that are made for explorers with 5.0's?
Radiator: A stock mustang Radiator will work just fine, i'm sure. Anyone know of any complications about installing it?
Now for the tranny, I'm going to be using a T-5 mustang tranny with an AA adaptor going toa Dana 300. (I know the D300 is a passenger drop, my next project is a solid axle with Passenger side Pumpkin
Anyone have a T-5 installed in a 95 newer explorer? If so, what did you do about the tranny crossmember. Did it have to be moved forwards/backwards? Or can it still work in the stock location.
Clutch: This is what I am confused about the most. Will it be easier to use a Slave Cylinder or a Throwout bearing? And, Can anyone explain to me the difference in the two?
I'm prob. getting in a little over my head with this motor swap. But, that is how I learn things. So, ANY tips, or help that people can give me will be MUCH appriciated.
Thanks,
Kendal
Thanks,
Kendal
