31 or 32" studded snow tires?? | Ford Explorer Forums
PUR PONY
CT
96 LTD, 96 XLT, & 98 XLT
I was wondering... does any tire companys make a 31 or 32" studded snow tire for 2wd or 4x4 trucks??
website? brand?
thanks
Marc
I know the Pro Comp Mud Terrains are pre-drilled for studs. They don't come with the studs, but if you live where they are ecessary, any tire shop should have them available to install for you.
I think wild country tires are too
thanks for the info. so a tire shop can install the studs for me? how hard is it to install studs? could i do it at home?
Stupid question:
Why do you need tire studs? Are these gonna be tires that you're ONLY gonna run in the snow? Cause studded tires without snow are bad! Most decent all terrian tires are good in snow nowadays, most drivers will never need studs.
kumho road ventures MT. check them out at tirerack.com
Firestone used to make some....you might want to check there.....
My girlfriends uncle has Buckshot Mudders on his plowtruck that are pinned, and work great.
most any MT tire has them pre holed for studs... its just your choice.
Be careful of buying MT tires for snow use. Many MTs have a hard rubber compound so they are tough, but this compound gets even harder in cold weather, probably enough to offset the studding.
BTW, Alec, I pretty much agree with what you say, but the stopping traction between studded and non-studded tires on ice is like night and day. Up here in New England many people swear by studded tires.... Me, this is my first winter with my BFG ATs and they are awesome in the snow from what I've seen.
