2002 XLS has got me puzzled 200k miles 4.0L
Starts well idles great
No codes
Hot here over 100F
Drives fine for 15 to 20 minutes and then acts like a minibike with the choke on. Lacks almost all power but still will idle perfectly. Also out of gear engine will rev up. When you key off for a couple of minutes it will go for another 15 -20 minutes before the same thing will happen. If you lay into the gas when it is happing it will spit and sputter a little but I am thinking I may be hitting the wot cutout when pushing the gas trying to get something out of it.
So far I have
Searched all the forums I could find
Cats have been replaced (most common cause found for lack of power)
Fuel Filter replaced
Fuel Pump is new and running at 68psi
checked for vacuum leaks and found none
With Forscan I checked
MAF voltage - good across the range with the reference numbers I could find
TPS voltage- good across the range with the reference numbers I could find
Pulled cleaned and tested the EGR - was not dirty and used hand vacuum to check movement
Pulled and cleaned IAC since i was there but it Idles great
ECT in forescan matches the temp gage and is running in the middle
It is not happening in the transition open and closed loop as I made sure it was closed before and still the same
Fuel trims look ordinary within a few percent of 0
initial thought was it was temperature related but with the 2 min key off the engine only gets hotter from the short soak.
All ideas or insights would be appreciated
