I've got a 5.0 as well and this issue has been discussed numerous times on this board through the years. The design of the 5.0 does not allow much coverage of your cylinders when you go in through the brake booster line. Sort of like "pissing in the wind" is how it's been described.
The consensus view is that going in via the PCV valve vaccuum line is the way to go with the 5.0. I couldn't agree more after using the brake booster line a few times and FINALLY figuring out how to get at the PCV line (hard to reach). WAY more smoke and much better results. I had a persistent ping issue (pretty common with the 5.0) and only the PCV method got rid of it.
There's a huge thread on this method
here. Well worth your while to try it.
p.s. Sorry to hijack. This thread started with questions about 4.0 and Seafoam after all.
