Pollarican
- October 10, 2006
- Wall Township, New Jersey
- 1991 EB 4dr
Hey guys,
I know this has been covered time and time again but I am kind of in a novel situation. I have a 1993 I'm building, taking parts from a 1991 I had previously built/ had geared. The 91 had 4.56 front and rear, but the rear are garbage. I just finished building a 410 Cammed 4.0 with a fresh hone/ bearings/ Stainless valves and all wear out parts replaced. I'm torn whether or not to buy new 4.56, and get it back in action the way it was (which seemed like pretty ideal gearing), or to buy 4.88s for the front and rear. The explorer will be my Daily driver, with at least 50% highway driving. I might tow a flatbed trailer that weighs roughly 1500 to move things and collect firewood etc, and give my old Inline 6/C6 E250 a break from insurance. Realistically, If I were to go to the next level with bigger tires, Id probably build a set of axles. I supposed it would be nice to have a set of 37" skinny tires If I could get my hands on them, but I wouldn't use them often offroad in fear of breakage.
It seems if the stock tire size was 29 Inches:
To match 3.73 stock tire performance, I would need a 4.50 gear ratio.
(4.56 R&P)
To match 4.10 stock tire performance, I would need a 4.947 gear ratio. (4.88 R&P)
(While running 35 Inch tires)
Would the 4.56 produce better gas mileage? The power was pretty solid.
I put a built 4.88 8.8 in a friend's Heep, and It was way too much gear to be highway driven - the thing wound out at 65-70 real high rpm. I don't offroad as much as I did when I just built the 1991, so I'm torn on what to do. I know I could work some towing power out of the higher gear, but I will only be doing that a small fraction of the time - not going to be pulling a car or anything.
If It helps, I'm running a M5ODHD trans from an 03 ranger.
(4.56 R&P)
