I have front auto locker's in 2 rigs, and it can be a bear to steer, and even stops me from making full turns when in a tight hairy situation. 1st gens locked steer easier then a 2nd gen locked with stock steering. Gearbox vs R&P.
I have the CAD axle in the 2nd gen, and can disconnect the pass side if that happens to free it up. I am contemplating on getting the Ected Max to replace the auto in this rig. I like everything about that locker for this rig. Wire routing on a 2nd gen is simple and unobstructed to the front diff. Having LS up front in a overlanding type rig is awesome IMO, and only switch to full lock when absolutely needed. Thats a perfect front combo for both pavement & trails. Normal LS lock up is progressive and locks close to 90%. That makes normal street / trail operation handle easily.
I have an auto locker in the front of the 1st gen, and it isn't as bad, but there are times I wish I had a selectable locker. Like on the street during snow storms. I used to be able to lock the hubs, and drive with them locked with an open carrier, and turn on 4wdH on the fly. Can't do that anymore with the locker. I have to be stopped and lock the hubs manually, then turn on 4wd and go. If there was a solid snow pack 100% of the time, I could drive with the hubs locked, but that just doesn't happen where I am. Off road, off the pavement, is not a big deal to leave them locked all the time, as the tires will spin as needed with no harm to the diff guts. This would be the reasons for changing from auto to a selectable on this rig, if I ever felt like it. Wiring the front locker on the 1st gen is less desirable tho.
My Bottom line is this: A selectable front locker for a rig on/off road both, is the best for a reason. The full lock up is there when wanted, and open when not needed. The less it's used, the easier it is on parts, and less chance of breakage leaving you stuck or stranded with a broken axle/hub/carrier.
There are different types of selectables these days, you just have to decide which works best, and in your budget. Auto lockers also work very good, are way more affordable, and are dependable for the most part. You just have to decide if you can live with the trade offs they come with.
A side note...... I do not know if this is true for all, or everybody running detroits, but I know a few people that broke an axle shaft, and in turn it grenades the locker & carrier as a result of not being able to absorb all that energy release. None of them replaced with a new detroit, after witnessing the carnage and additional costs of a re-gear, diff rebuild.
As far as gear choices goes, there are not that many actual manufacturers for them. Most are just bought and re-branded. The difference to really look for is the number of cuts used to make them. Cheaper gears are mostly 3 cut, and the better/stronger/quieter gears are 5 cut. Yukon, US gear, & Richmond are all 5 cut I believe.
