4R70W - False Neutral? 1997 Explorer 5.0 AWD | Ford Explorer Forums
Blue Coupe
Calgary
1997 Exploder 5.0 AWD
I have a 1997 Explorer, 5.0 AWD with a 4R70W transmission.
If I run WOT in 1st or 2nd gear and lift at high rpm (4500-5000ish) and the transmission attempts to shift, there is a false neutral for several seconds. Then the transmission shifts to the next gear.
If the truck is driven normally there are no issues. There are no codes and the fluid level is fine.
Suggestions?
Thanks
