Steven G Webb
- April 13, 2019
- Saluda
- 2007 Explorer Limited
Attempting to solve the rumble strip, engine surge problem I decided to tackle the spark plug replacement yesterday afternoon. Couldn't find a 9/16 spark plug socket (thanks again Ford) so had to go with a deep socket and use a magnet to retrieve the plugs. Ran a can of Sea Foam through the fuel tank, then did the upper treatment pouring a can down a vacuum hose. I also came armed with a can of Sea Foam Deep Creep penetrating oil. So go the engine cooled back down and got the coils off and out of the way. Shot a little Deep Creep into socket well #8 expecting it to be the most challenging. SURPRISE! I backed it out about an eight of a turn then ran it back in. Worked it out slowly. There was a little black (Carbon?) buildup on the shank below the threads. Pretty much lather, rinse, repeat for 7,6,5,1,2 and 3. Naturally the one with the least visibility and access would cause a problem. Got to #4 and it was not budging. I did not force it. Sprayed the Deep Creep down the well and left well enough alone. Darkness was setting in, so I began installing the new plugs with Anti-Seize applied and I put the coils back on (did not replace them at this juncture). So I had a 7 plugs in, coils on and the connections for the coils and injectors back. Now it was dark. I though I'd see if that remaining plug would come out. I put the socket down the well attached to an extension. I began "hunting" for the socket to seat on the hex head but could not feel it drop into place. I made a few attempts and began turning the extension, felt no resistance. I was frustrated and it was now too dark to continue.
Today I ventured back out. Daylight isn't a great advantage when working on either #4 or #8 but at least it was warm. Again, I eased the socket attached to the extension down the well and again did not feel it seat. I turned the socket several turns in both direction. I felt no resistance did not feel any friction or grinding. Couldn't sense any wobble in the ceramic tip though I could not reach it with a finger, just the magnet and a screw driver. In absolute frustration I put the coil back on and connected everything back up.
The engine cranked and started right up, no misfire. I expected a dead miss on #4. So now I have questions. If I broke the plug initially trying to back it out, wouldn't I have felt it snap? And if I managed to break it without feeling it give, could it still function? I'm likely to contact a dealership and find out what they'll charge to remove and replace this one plug. It's too weird. Also, this after though: I'm at at least the second owner and don't know about any previous plug/coil changes but the plugs I took out are Autolite and I don't know if they are subject to the same breakage as the Motocrafts.
