ahodges
- August 31, 2009
- Millbury, OH
- 1996 XLT - 347 S/C
I own a 4x4 1996 Explorer XLT with the 4.0
The winter months are aproaching so I tried my 4WD for the first time since the middle of the summer. When I went to engage the 4WD auto, it acted normal and engaged. However, when I accelerate there seems to be excessive vibration. Also when i turn a corner, the truck clunks and the tires squeal (without a doubt the front axel is locked). Since I've owned this truck for 5 years now I know it is not supposed to do this in 4WD auto on dry pavement.
The other symptom it has is the transmission will not shift out of first gear when the truck is in 4WL unless the RPM's are above 3,000 and will not go into any other gears. It has never done this before either.
When I put the truck in 4WD auto the correct light comes on and then shortly after both the 4WD and 4WL lights flash simultaneously 6 times, then off for about 2 minutes, then repeat. This continues no matter if it is in 2WD or 4WD until I shut the truck off and restart it, then it is normal until I try to put it back in 4WD.
The transfercase is full of oil and was changed only 25,000 miles ago, no water is in the oil.
Does anyone have any idea what the problem is? I'm very mechanical and can do my own work but don't know where to start with this one. Thanks for your time in this matter.
