4wd low help | Ford Explorer Forums
4wd low help
huntingdeer
alabama
97 ford explorer
Ok 97 ford explorer contrôlée track 4x4 4.0
4 low only works when car is cold(not driven far) I've replaced both electronics gem and other box and a sincer on the tranny near driveshaft.when I switch to 4 low it does nothing or sometimes the light comes on but nothing.im to the point where I'm lost.what else could it be motor? I would not think so.when you here the click in the dash it is going to switch.no click no switch.its in nuteral foot on the brake and it does nothing when the car is worm.any help?
Check the plug to the Electronic Shift Motor is connected correctly. If not, the motor may be going bad.
agreed check the motor.... it is usually the first to go out in the system.
