ronking
- February 9, 2003
- San Jose, Cal
- '95 XLT
I've got a '95 4WD Explorer, and typically don't use the 4WD all that often.
Every now and then I try to exercise the 4WD hardware, but the last time I
noticed a peculiar problem.
When put into 4WD low, the truck engages the 4WD and works okay. However, if I turn the wheels sharply the truck comes to almost a complete stop; it feels like the front wheels are locked and the back is pushing the front end. Again, this only happens when the wheels are sharply turned either to the left or to the right. This problem doesn't occur in 2WD, and there's no appearance of tire rubbing anywhere.
At first I suspected the CV joints but then I would have expected the problem to occur in both 2WD and 4WD. I thought it might be something in the front differential or transfer case, but the truck works fine in 4WD as long it's going straight.
Any ideas before I get it checked out?
