Glen4X4
- June 5, 2007
- Lewistown, Pa
- 2000 XLS
Well after takin the exploder through the back yard exercising the 4X4 so the tranfer case or nothing else locks up (I do this every so often if I havent used the 4X4 in a couple weeks) but anyway I looked through a couple diff. threads and have not found an answer, when I was driving its very noticable when you slightly turn the wheel it crunches a hellin someone 10-15 feet away would probably be able to hear it, the 4wheel drive is still working awesome, I tried goin up over a steep hill that normally would spin right away in 4X4 went up over it in high and low range and didn't buck or studder or anything and I know that you can't take sharp turns with it engaged but still it shouldn't be making them noises in 2wheel drive its fine just has some squeekyness with I think has to do with some fer bushing aint sure of that yet but, could the axle maybe need a greasing or what? Because I tried I left the hubs locked in and disengaged the transfer case and drivin turning still makes crunching/squeeking noises almost as bad as if the 4X4 was engaged, so any advice would be very helpful. Thanks to anyone that applies some advice/recomendations!!
