4x4 high and O/D light flashing | Ford Explorer Forums
Xlthunter
Eastlake ohio
2004 explorer xlt
just bout this at an auction I noticed the abs wires were cut on both front wheels but also needs wheel bearing hub assembly’s so I ordered them with the wheel abs and rings included. Would these wires being clipped be the culprit to the abs, 4x4 high and the O/D off lights flashing? Just hoping after doing the wires to the abs it fixes these issues. Any input is greatly appreciated
It would likely be the cause of the abs and 4wd lights flashing, but the flashing OD light is probably stored transmission fault codes.
Also throwing a pressure control solenoid B code
Sounds like a pan drop is in order. That’s the cause of the OD light flashing.
