4x4 not engaging | Ford Explorer Forums
4x4 not engaging
t scott
albuquerque new mexico
93 XLT 4x4 4.0L 4Dr
the 4x4 is not engaging. there's no noise, no light indicator for four high or four low. it just didn't work the last time i went to engage it. the fuse is good. what do i look at next?
hit the round silver motor on the t-case with a hammer. this worked with mine. I had the same problem. Does it work sometimes, and not others? Give it a try.
hey blaine.....
Do you like your Force II system? Is it loud. I want one but I don't want something excessively loud. The wife would not be happy with that!!
if your feeling adventurous
try this link:
Dead Link Removed
when mine quit working, this basically what a friend did to mine and it worked.
todd
:hammer: this worked thanks! but now i can't get the wife to jump out, crawl under the truck and tap on that little silver motor. should i replace it (the motor not the wife)? where can i get one?
you might try kensington auto parts 1-800522-2897, i believe they are part of a nationwide network of bone yards owned by ford, also did you get a chance to read my previous link, i had the exact same problem as yours and this did the trick it was pretty easy to do, and it solved my problem for over a year now.
todd
maybe i need a bigger hammer cuz mine will not engage unless i was tapping on it while my brother was pushing the button.
