5.0 metal heater core manifold | Ford Explorer Forums
66427
Clarksville, TN for now...or forever
01 EB
I'm putting the truck back together and would like to replace the set of metal tubes that run down the passenger side from the water pump to the heater core. I ordered the replacement, which the salesman assured me was correct, but it appears to be a push in with three gaskets, vs the original appears to be threaded.
Couple of questions for any body that has ever replaced them on a 2001 5.0;
1) Is this the correct set?
2) How do I remove the original? I have a 1-1/16" open end on the lower "nut" and it's not budging. I also put a pry bar in between and again, no movement.
Does it need more force, or is there a trick.
Thanks in advance, and yes, I used the search with a few different variations but came up empty.
Once again, trying to figure out how to post pictures...
Never mind...got it.
