Xeek
- March 21, 2010
- Virginia Beach, VA
- 1991 xlt
Have a 97 5.0 past month or so it started as I would turn right at a little more than a 90 degree turn into my driveway. One of those sloped gutters that pops you up some. By the time both front tires get up it tries to stall. If I go slower it will stall, if I just keep my speed and lightly accel it won't do anything. Literally no other turns or bumps cause it, just my driveway lol.
About two weeks ago sometimes it'll stumble a little for a couple seconds after starting it, I think all cold starts. Around the same time when it's warmed up and I run into the store when I come back if I don't wait like a minute or two before putting it in reverse it'll stumble or stall depending on if I give it enough pedal or not. If I wait long enough it's perfectly fine. It's also fine if I put it in drive.
I tested that once and it would idle 700-800, dip to 400-500, then back up, etc. I switched to drive and boom it's fine, back to reverse, and it's back. After a few times it worked itself out and was back to normal cause it had been running a couple minutes.
I had a spare iac new laying around so I swapped that in, no difference.
I also cleaned the maf, no difference.
No codes being thrown at all. I have an edge insight digital gauge/scan tool thing. I can see values of stuff as I'm driving of whatever the computer can read. Maf, fuel, o2, temps, etc. I could provide any values that might be helpful.
