Willcall
- October 22, 2008
- Wolfforth, TX
- 98 XLT 4x2 | 20 XLT 4x4
It's a 2001 5.0 AWD and is Low Emissions Vehicle (California Emissions) equipped. Purchased in November '14 with 104K and now has 130K.
The problem started about 3500 miles ago/ mid June and has happened a total of 5 times. It starts with the car acting as if there is no throttle input (it down shifts fine, as if I were coasting to a stop). When it comes to a stop, it idles fine for a second or two and then begins to miss VERY badly with the RPM dropping very low. After that it (1/5 times) begins running normally again after about a minute or two or (4/5 times) stalls out completely. When this happens, it starts up like normal and then begins stumbling/ stalling almost immediately after. I've noticed that if I turn it off and leave it for 2-3 minutes, it will run normal after that. 3/5 times it happened while idling at a stop, 1/5 coasting from 75 to 55, and 1/5 at full WOT while passing a car. None of these events has triggered the CEL. During the most recent, I was outside of the car couldn't remember hearing the fuel pump whining like I can normally hear it. The fp has whined constantly since I bought the car, but I was assured by a Ford tech that it was probably just an non-factory fp. My fuel economy has stayed the same http://www.fuelly.com/car/ford/explorer/2001/willcall/346830
I hooked it up to my SCT XCAL3, it data logs the fuel pump duty cycle at 1.000 (100% ?) at idle? Also, the fuel trims are between .980 and 1.004 at any given RPM. Is this normal?
I have replaced the TPS sensor (it was bad) and the CPS/Synchronizer (it was squeaking) was replaced in March.
Could this be an intermittent MAF issue? or fuel pump going bad? O2 sensors? Something I'm not seeing?
