ford99_1979
- August 17, 2009
- Calgary, Alberta
- 2020 ST
I have performed a search and I see discussion and threads about the 4.0L thermostat but could not find anything on the 5.0L thermostat directly. I have had a leak for a long time and finally got around to removing my thermostat housing. I see a combination of paper gasket and silicon sealant. I cleaned up my thermostat housing with a dremel and wire wheel and noticed it does not have a good sealing surface on the cast thermostat housing. I don't have good faith that this sealing surface and the paper gasket are going to do the job and I hate to have to do this again really soon.
My question is what do you guys do for a good and permanent seal?
Here is the questionable sealing surface.
