5 speed tranny temp gauge | Ford Explorer Forums
acschilling
CO
92 XLT
Ok. I've read a ton of threads about temp gauges...all seem to be for automatics. What about a manual? Where is a good spot? Help? Thanks bros!
The reason there are a bunch of threads about temp gauges on automatics is because they're far more sensitive to heat than a manual transmission is. The #1 killer of automatics is heat. That's also why there are external coolers for automatics as well. Automatics also have fittings for the express purpose of running lines to a cooler whereas a manual won't have the provisions to do it.
There isn't really much of a need for a transmission temp gauge on a manual transmission unless it's a high performance unit like would be used in NASCAR or F1 racing, but if you really want to add one you might be able to remove the bolt that's aft of the fill plug and use that for a gauge probe. If that doesn't work, you might end up having to drill and tap your own hole.
There's no need for a temp gauge on a manual. Not even my 300hp Acura has one.
Thats pretty lane but I kinda figured... reading threads and actually looking at it. Oh well onto the next!
Look at it this way....
A manual is nothing but a gearbox. Like the rear end. It's filled with fluid to lubricate, not so much for cooling.
An auto needs pressure to work. It needs a pump of some sort to move the fluid around. As a result it gets hot.
