Dapped
- February 25, 2009
- 2003 Explorer 4x4 XLT
Hi Guys,
Need some advice here. I'll keep this in point form for easier reading.
Problem:
Select Reverse and instantly feel a bit going in but not fully engaging.
Bring up RPM and it bangs into gear then releases then bangs in gear then releases, this will continue to do this until I back off on the throttle. Have to watch were I pull into so I don't have to give throttle for reverse, just easing it for now.
Conclusion:
Not getting full reverse.
History:
Transmission was rebuilt at 180 K, now 205 K
Servo Bores were done with brass sleeves on the OD and Intermediate Bores.
New Solenoid block installed.
All gears from 1st to OD work fine and shift smoothly and seem to shift at the correct RPM.
I have read and read and read and found nothing similar to my condition.
I'm thinking it may be the reverse valve in the valve body and was thinking to order a new valve body online and trying it but sure would appreciate the opinions here before doing so. I could be on the wrong track here.
Thanks and hope to hear from you.
Regards
Don
Problem:
Conclusion:
History:
Regards
Don
