5R55E compatibility question. | Ford Explorer Forums
falnangl4u
Can anyone please tell me if a 1997 ford explorer 4X4 transmission will fit into a 1999 of the same? Or if there is some easier cheaper fix for it as the reverse has went out. Thanks so much!
Unfortunately a 99-01 are the only ones that will fit.. They are slight differences in the 5R55E between the 97-98 & 99-01
welcome to the site
Welcome to this forum! I've renamed your thread, and moved it into the transmission section. The 97 has an extra sensor that the 99 doesn't have. You could install it into the 99, but the sensor will just be disconnected. Check to see if the range sensor has the same number of wires. If not, then you might have to swap that part. As for your problem with no reverse, check the low/reverse servo, band, and reverse modulaton valve in the valve body. Sometimes it could be a problem with the shift fork in the transfer case, and not even a transmission related issue.
