pilotmogge
- August 1, 2013
- Sollefteå, Sweden
- 1999 Explorer
Ok, I got my cheap chinese ELM327 Bluetooth reader the other day. I ran it with 4-5 different softwares, freewares or trial, incuding "Torque" in my Android pad.
None of the softwares have reported any errorcodes whatsoever, not a single one!
Not even while O/D lamp is actually blinking.
After driving my 99 ex for a couple of weeks now I Think I can narrow down my tranny problem into just a TC lockup problem. All other functions in the tranny seem very smooth, quite and accurate. No slips or hard shifting as far as I can tell.
I doesnt lock up sometimes, and in some cases it seems do have more difficult to lockup in the slower region, like in 3rd cruising around 30-35 mph than in the faster situation in 5th over 50 mph.
There are Days when it works great without faults, and there are Days when it sometimes fail to lock up, and in some cases the od light doesnt even bother to start flashing...
My hope is that it cant be all dead, since it locks up in more cases than it fails and naturally I wonder where to start looking for the causes.
I've been Reading a lot about this here and on other sites, and found that there are so many other sensor values that are involved in the process that feeds PCM in order to signal the tranny to make the right shifting.
How odd it might look, the problem may theoretically lie outside the transmission, such as Engine/tranny temp, BOO switch, MAF, throttle position or other sensors, or even just a bad/faulty Electric Connection.
Or, is it possible that old oil, or wrong oiltype can cause this isolated symptom?
Where should I start?
How can I assure that necessary sensors give the correct information?
Where do I look for bad Connections?
Can a simple oil flush solve it all?
