cobo351
- July 19, 2012
- 2001 Sport Trac
My 2001 Sport Trac had the 2-3 shift flare for awhile and recently (overnight) started slipping in reverse and drive. I have good lock-up in low. So i pulled the pan and found the sparator gasket blown around the servo piston cover. As I was in the middle of putting the VB back on with a new bonded serarator plate I found what I have learned to a needle bearing. After a little more inspection I found two more.
Question one...should i pull it and rebuild it?
Question two...what is the difference between a transgo and a sonnex valve body kit?
Thanks
Cory
Thanks
Cory
