TiredOldTruck
- March 7, 2020
- Ft worth, TX
- 2004 Ford Ranger XLT
Title says most of it, here's the details: I was driving home and the trans lost power for a moment, then came back, and after I braked for my exit, I couldn't accelerate in D anymore. No codes. I put it into Man 1 and was able to drive the last 1/4 mile back home and started testing things out - the engine revs freely and without any odd sounds in R, D, and Man 2 but I get no engagement. I can put it into Man 1 and drive without issue.
I pulled the pan/VB today and examined everything, the seperator plate is intact and undamaged, the check balls, solenoids, puck, and springs are intact, clean,and undamaged. All electronic solenoids are dead-on in-spec resistance-wise, and the TSB deleting the screen and installing an overflow BOV looks like it was performed.
No burned smells, wire harness is in excellent shape, no obvious glittery bits in the pan either.
The EPC has some wiggle room to move in and out with the bracket installed, but not side to side and the bracket does not appear cracked or worn at all.
I've had some miscellaneous symptoms for a while like it taking a moment or two for the trans to engage when putting into D(if I let it idle for a moment first this doesn't happen), thumping while engaging from P to D(again, idling a moment fixes that), the 2-3 flare, and a couple very hard shifts up and down when I've had to punch it on the highway to avoid an accident.
I've also had more-frequent issues with it not wanting to crank while in D until I jiggle the shift lever a bit. I went ahead and ordered a new neutral position switch in case it's finally gone bad (220K on it), but I can't test that until everything is put back together and refilled.
What else could be the problem? I saw something about a sprag on the output shaft or in the planetary gear portion, but this is my first foray into transmission repair so I'm unsure.
