5R55E with no forward gears. | Ford Explorer Forums
Bear808
Hawaii
2004 Ranger
I wonder if anyone can help with this problem I have a 2004 Ranger 4X4 with 5R55E Trans, The orginal problem was flaring I replaced the seperator plate and gasket also replaced the VB. It fixed the problem. That was a 18 months ago. It now has no forward gears reverse works fine and i just replaced the low/reverse servo seals with no improvement, not sure if i should replace trans or continue trying to fix it
welcome
Welcome to this forum! I've moved your thread into the transmissions section. Did you use a 1/4" drive In/Lb torque wrench on the valve body bolts? It's possible that they might have gotten loose.
