BlakestaExpo
- July 27, 2008
- Nassua, NY
- 02' XLT
I'm Confident I've read every thread on this website pertaining to the 5R55W along with the PDFs posted and all the rebuild/shift/VB/solenoid threads.
So here's my deal, any insight, opinions, or thoughts would be great.
101,000 miles,
-around 100,500 i started having a serious 2-3 shift flare, not a big surprise at all. I plan on replacing the Solenoid and valve body to fix that.
-Now I'm noticing that in second gear (and only second gear) I'm having some slipping, ill be in gear, go to accelerate a bit and then RPM'S will go up, but not so much the speed. However if i drop the shifter into 2, I can PUNCH IT with no problem.
--Planning on tightening the intermediate band to fix this?
Today I changed out the fluid and filter for the first time since I've owned the truck, and it was NASTY, but lucky not a single bit of Metal shred in the pan and the fluid didn't smell burnt at all. I cleaned out everything, reinstalled everything and filled tell the drip, then tightened it up.
My thoughts and questions,
During my draining i thought it would be a great idea to drain the torque converter also, but i spun the entire thing around by hand twice, and i couldn't find the drain plug, any advice to something I'm doing wrong? To my understanding the 5R55W has a drain plug and the 5R55E does not I was looking through the rubber plug on the bell housing that's meant for just that, but no plug!?
When down shifting from third to second to get on the highway, my truck misses completely and revs to almost the restriction plate before slowly catching the gear and accelerating, any insight on this problem?
Thanks in advance to anyone who responds to this.
P.S. After changing the fluid and everything today, definitely shifts better, although i haven't gotten out to give it a real run, tomorrow ill tighten the bands and hit the road.
Thanks,
Blake F
101,000 miles,
Thanks,
Blake F
