monkeybuttons
- July 19, 2011
- Ogden, Utah
- '02 Limited
I own an 02 limited 4x4 with 70k miles. It currently slips when shifting 1-2, but mostly under heavy load/acceleration. It shifts okay if I granny it. I haven't found many posts about 1-2 shift problems.
I talked to a Ford tech and he said it sounds like the intermediate clutch is slipping, but the 5r55w doesn't use an intermediate clutch. I can't seem to find what IS slipping (i.e. what clutch set is used in the 1-2 shift). I have read many posts in the forums and repair/part manuals and guides and I still don't know.
Also, it seems the tc will lock-up then unlock every 2-5 seconds sometimes, both under light and heavy acceleration. It may even do it while cruising, but I haven't noticed it. The Ford tech said that is from a bad valve body.
What do you transmission guy's think?
Oh, I don't know when the transmission fluid was last changed because I've only owned it for 5 months. Could a simple fluid change fix these problems? I checked the level and it is correct. -Sorry for the long post-
