UK 4.0 Explorer
- May 17, 2010
- England, United Kingdom.
- 99 XLT
Hi, I have searched nearly everywhere for an answer with no success and hope that there is an expert on here with the simplest of answers.... here goes:
1999 UK Spec 4.0 (face lift north face model) AUTO.
35000 miles.... only just run in! (genuine miles, family have had the car since new).
Was running perfectly, until 6 weeeks ago when it just died pulling off the motorway at about 70mph.
Engine management light came on.
The engine starts as sweet as new, revs reluctantly, but you can get it up to 5000 if you do it a bit at a time. it pops and bangs at 5000 but only a misfire, nothing too noisy.
Put it in gear.... push throttle.... dead.
Put it in gear, ease throttle about 1% and it will sneak upto about 10mph. if you over throttle it, it will die, no chance of easing off and recovering.
Sort of seems to run on 3 cylinders (one side) as its revved with no power at all once in gear.
Local Garage (non ford) thought Catalytic converter had colapsed choking half the engine.... tried removing cat it and its not that.
3 engine codes....
p0743 TCC system electrical failure,
p0750 Shift solonoid no1 failure and
p1747 EPC solonoid short circuit.
All reset.
Garage has had the car 6 weeks now and is about sick of it. Im stuck too.
There is also an air sucking noise as though the air pipe has a hole in or the air intake is partially blocked.... the garage has smoke tested the inlet system and they say its fine no holes, no blockage.
Local garage is about to drop back to basics and try coil, leads, spark plugs next... but as it died like hitting a switch i cant see it being those. It runs so well at tick over that you wouldnt know it had a fault!
Please help. Garage dont even consider the only idea i have found online,by typing "explorer loss power air suction noise" into goocle then hitting page 176 or something like that..... the rear timing cassette loose. They think im mad.
ANY ideas would be welcomed. and i am very sorry if this has been answered, but i have looked... for 6 weeks.
3 engine codes....
All reset.
