7 month oil change | Ford Explorer Forums
7 month oil change
Techmonster
St. Cloud, MN
94 Limited
any experience from you guys that run mobil 1 or amsoil. i used to believe the old saying 3 months or 3,000 miles on dino oil, but now i have been running mobil 1 in my 5.0 for about 2 years. i put on about 3,000 miles every seven months. should i be changing my sythetic oil a little more frequetly. i mean if i wait 10,000 miles to change my oil it will be almost two years. anyone done an oil anylis on something like this
thanks
I think the Mobil 1 container used to say 12 months or 20k miles with regular filter changes; I took that to mean filter change every 3 to 5 k miles. We used to have annual emissions checks so you did an oil change to make sure you passed. I think some of the newer containers say 15k miles and regular filter changes. Since you add nearly a quart with every filter change and the synthetic does not break down like a petroleum/paraffin based oil would. Now if you do a lot of stop and go driving use some common sense but I have not had any problems.
Amsoil Series 2000 is a 35k miles/1 year ( whichever comes first ) oil.
Dead Link Removed
I have a 5.0 Explorer and I have run a 10,000 mile, between 7-8 mo OCI once. I used Amsoil 0W-30 and an amsoil filter. No problems at all, no consumption. I had 40k on the truck when I started the oci.
I have since gone to Mobil 1 5w-30 w/Motorcraft filter and running 5k OCI. The reason? If i was going to continue to run 10k ocis I would have to run some oil analysis to see if everything was going well w/ the oil. For the same amount of money I could do an oil change, which I like to do, and not worry about testing.
But to answer your question, you should have no problem going 3k in 7 months with Synthetic oil. Heck, I say pusk it to 1 year if you are driving that few miles. Just make sure you PCV valve is in good working order.
I've put about 7000 miles on my X since I've changed over to Mobile 1. My next step is to get the Amsoil BMK13 and run their series 2000 synthetic, like Aldive does.
I'm with you 302Xplorer, but might just go to 6k OCI.
I'd say use Mobil 1 and change it once a year. I do that with my mom's car. It has an oil life monitor but the book says to change it at minimum once a year regardless.
ive always been a 3k mile guy...but i may start doin it myself and using synthetic, now that im over 80k
Definitely go for it.
