compdoc777
- April 5, 2004
- Cypress, TX
- 95 EB, 98 EB, 01 Exped EB
Would I need to get one with EGR or would I not need it?
SilverBullet said:Depends on your emissions testing in Texas, I would say.
tmsoko said:Also keep in mind the 90 degree elbow is 65mm ID, so a larger throttle body isn't going to help that much. When I got my Accufab, I bolted it to the elbow, opened the throttle plate and looked right at the 5mm edge all the way around the opening where the TB and elbow meet. I eventually made a custom 90 degree elbow with a 75mm ID, but the effort involved and the benefit are questionable. The stock elbow can only be opened a few mm, not enough to gain true benefit of 75mm TB.
just mo $0.02
No. Stock is 65mm. For the cost and work it would take it would not be worth it just to gain 5mm.compdoc777 said:So do you think a 70mm would be better or work?
james t said:No. Stock is 65mm. For the cost and work it would take it would not be worth it just to gain 5mm.
You never did say, but what mods have you done and what do you plan to do?
