SteveVB
- July 8, 1999
- Gaithersburg, Maryland
- 04 Rubicon w/stuff
Good article about spun tubes and fixes for the 8.8 Interesting reading for anyone who is running bigger tires, and hitting the trails hard, maybe even not so hard- high miles?:
http://www.4x4wire.com/jeep/tech/axle/ford8_8/
Also a thread on JU about it-I cant get it to come up now though but a search in the wrangler section should pull it up. .
Anyone experience spun tubes, or broken spot welds(rivets/pins) at the rear axle. Im going to check my old axle(160k miles) I think it had some oil leakage at the tube/pumkin weld/pin holes.
Other fix is to weld the tubes at the pumpkin the full circumference - cast iron to steel tubes is specialized welding- pre-heat , but this would be the best repair IMO - also the most costly- dollars or time if you have the skill and tools
Have Fun.
Have Fun.
