Nick26
- June 30, 2003
- Cumberland, RI
- 98' 5.0 XLT
Alright I've done a lot of searching on this but have found mixed answers on this so I figured I'd get more recent poll of responses...
I have a limited slip diff and the cheapest locker that I can find for it is the No-Slip which I have heard works great but I am on a tight budget and at $400+ its a little much. So then the other option I have is the Lock-Right, E-Z Locker, or Aussie locker which are all right around $250, and swap in an Open Carrier as long as I won't have to reset the backlash. Some said they didn't have to reset the gears and it worked fine, other say you will most likely need to reset the gears. I've found a few threads where people said they did the swap with out resetting the gears and it worked fine. From what I've read it seems like if replace the shims and bearing caps exactly as they came off then it should work fine. Any one got any input?
Thanks!
Thanks!
