nova801428
- November 24, 2005
- Oregon
- 86 Ford Ranger
All the fusible links are fine, whats next?
okay so your fuel pumps both come on when you jump the relay, correct?
you have 12V + constant (from the battery) to the relay hot all times, correct?
But when you turn the key the fuel pumps do not prime like they should. even with all new relays, correct?
You still have no spark?
Where in OR are you? You have no city in your profile
Eeek whisperer the relays get a power feed from the computer when the key is switched to on.
true the fuel pump signal may be a - but the red acc + wire powers many relays and sensors in the engine bay.
The question is what did he jump? - or +
are both + feeds to the relay showing 12V+ when the key is on.
it is quite possible that this is a broken wire somewhere, a bad terminal/clip/pin in the relay box itself. You are getting battery power to your power distribution box, but not the EEC power feed when the key is ON
you DO have 12 volts to the relay, right? As I remember this the ECU grounds the relay to opperate it so you need the 12 volt on 2 terminals at the relay, the main power feed that gets switched in when the relay operates, and the feed for the relay coil (which the ECU grounds the other side to opperate it).
if you dont have 12V+ at any of the red wires, the first thing to check is the EEC fuse and relay.
Ok then, I'd pull the (supposed to be) switched wire from the relay connecter insert a wire into the relay connector and wire that to a 12V source. Then turn the key and see if the pump runs. That would test the entire circuit to the relay from the ignition switch. (ASSUMING that the ECU is grounding the relay coil like all the others). If that's is the case it get's down to a fairly simple curcuit supplying 12 volts switched to the relay
As I understood what he wrote he has the 12V+ from the battery but never gets the 12V+ with the key on.
