ross101
- April 5, 2011
- 87 ranger
87 Ford ranger. The motor runs for about 20 seconds then will both down and cut of even if you give it gas. throttle positioning sensor is good and maping sensor is good also. Not really sure where to go from here. I have replaced the fuel line and fuel pump. Also has a new fuel tank. When truck cuts off there is still gas on the fuel rail with a lot of pressure. I need help ASAP
