jimmy3fingers
- December 6, 2010
- hood river, or
- '90 bronco II 5 spd 4wd
can someone please tell me what size bolt is used to mount the starter on my '90 ford bronco II ? someone replaced the starter and had the same problem i'm having with " no work room " and put in a different bolt head size on top then the one on the bottom---got it started and left the bolt hanging without tightening it and the starter finally dropped out of alignment as the bottom bolt worked loose. The bottom bolt head size is 17/32. can the parts house help me with that little bit of info ? thanks....jim
