90mm LMAF & MAC Intake (5.0 v8) | Ford Explorer Forums
willzilla
San Antonio, TX
2000 XLT AWD
Will a 90mm LMAF be able to directly bolt up to the MAC heat shield (in the MAC intake) or will some kind of adapter need to be used? Or, should the heat shield be abandoned or something? Would anything else be needed to utilize a 90mm LMAF with the MAC intake?
I only ask as the truck, from it's turbo days, has 39lb cobra injectors in it and am trying to re-match a MAF to the injectors/etc before having everything tuned.
Thank you!
I think you might have to grind out the opening some but it will work with some light modification. You might have to drill new mounting holes but all you have to do is rotate the MAF 45* and then you can drill new holes. That would give you the ability to swap back and forth with the same mounting plate and air filter.
Hmm... Good idea :D Thanks!
